OK I have a set of BRAND NEW NEVER mounted DM inframes.
these are the Smaller of the 2 dm flanges (or the bigger of the 2 standard banshee flanges)
comes with all pictured
Just spent about $580 for them... will take $500 $485 $425 $400 shipped for a fellow BHQer!!!!
Guest stimbert
Lol what's the point of bickering over 25 bucks. It's a bad ass set of brand new pipes that he's already taking a loss on
Free bump, good luck with the sale
come on!!! someone snatch these up....
this is what they look like mounted and chromed (this is a used set I have)
What size dm are they for?
Edited by banshee(911)
They are actually the same pipe up to the 18 dm I believe. They should run pretty good on any dm you can put a small flange on. So for sure a 4-14 mil
the id is 1.8" or 46 mm it is the smaller of the 2 flanges. the larger flange is only 50 mm. so only 4 mm difference. you wont loose a whole lot of flow if you wallow out the smaller flange if you are currently running the big flanges.
