mattsny83 Posted February 29, 2012 Report Posted February 29, 2012 Any one ever had a problem with a pingal valve leaking????? I am running meth threw my banshee and the pingal wont stop the fuel from coming out when shut off slows down but not all the way. Some help would be great Quote
rjdgriff Posted February 29, 2012 Report Posted February 29, 2012 Mine is the same way so make this a x2 question Quote
Bkm2006 Posted February 29, 2012 Report Posted February 29, 2012 Yup mine started this got jeff at fast sending me a dual pingel. Quote
mattsny83 Posted February 29, 2012 Author Report Posted February 29, 2012 Mine is a dual pingale as well is there a way to rebuild them???? Quote
bigboybanshee Posted February 29, 2012 Report Posted February 29, 2012 You can send them to pingel and they can rebuild it. Worth a call, it should be cheaper than buying a new one http://www.pingelonline.com/fuel_valve_rebuild.htm Quote
Nieskes Posted March 4, 2012 Report Posted March 4, 2012 Pull the two brass fitting's off and replace the two orings that are behind them. Quote
