banshee_kills Posted February 10, 2012 Report Share Posted February 10, 2012 How Do I Know If My Water Impeller Is Effed Up And Isnt Pumping? Want To Make Sure Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted February 10, 2012 Report Share Posted February 10, 2012 How Do I Know If My Water Impeller Is Effed Up And Isnt Pumping? Want To Make Sure Just drain the coolant and pull the cover, dont risk it. Replace everything. It's too cheap NOT to do. Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted February 10, 2012 Report Share Posted February 10, 2012 Start the bike with the radiator cap off and rev it a little, you should be able to see the coolant circulating back into the radiator. Pretty good indicator it's good unless you hear noise coming from the impeller area. Quote Link to comment Share on other sites More sharing options...
banshee_kills Posted February 10, 2012 Author Report Share Posted February 10, 2012 Thanks bro, just want to make sure since its been said that the banshee water impeller comes out defective for being made out of plastic which makes it easy to melt Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 10, 2012 Report Share Posted February 10, 2012 Gotta figure there's a reason it got hot enough to melt the impellor to start with Quote Link to comment Share on other sites More sharing options...
