Foxtrot Posted February 6, 2012 Report Posted February 6, 2012 Does anyone knows the quantity (and grade) of oil inside a stock rear shock ? Quote
So Cal Suspension Posted February 6, 2012 Report Posted February 6, 2012 Out of the probably 400+ rear shocks I've done, I don't think I've ever measured oil quantity... I set the IFP, and fill er up. Viscosity is going to vary depending on what you're setting the shock up for. Typical weight for the rear is anywhere from a 10-12wt... if you're heavier, run a 12wt, lighter, run a 10ish. Amsoil Shock Therapy, Medium #10 is a good oil that is readily available. 1 quart will be enough, and you'll have some leftover. Set your IFP at about 3/4 Nitrogen, 1/4" oil... Quote
