I had got a banshee but I did fresh o rings for the cool head and put it back together and it is leaking from somewhere I don't know where but before it was the plug in the back of the engine on top but I don't think it's leaking again it wouldnt hurt to look but my shee starts and when it do it idles too high and back fires a little bit
Are the spark plug wire on right? Does it have an adjustable timing plate? Set at 4 degrees advanced. Are the carbs dirty? Does the choke being on help with back firing while riding? What pilot jets do you have?
All I can think of ATM.
Adam
you need to give more info... whats your jetting. whats done to the motor.. when you did the orings on the coolhead did you coat them in grease? its really easy to pinch an oring.. did you do a leakdown test? anytime you open your motor and reseal id do a leakdown... backfiring and high idle is lean.. whats your pilot jet? how many turns out on the air screw? first thing id do is the leakdown test.
Don't know what's all done except for pipes, bore, and cool head the guy i got it from was dummy he aint know shit
You aren't coming across as a brain surgeon yourself :jesterlaugh: . Clean carbs one at a time as parts are different. Make sure pilots are pussy clean. :rotflmao: When you have them apart write down your jet sizes and clip posistion. Set float height. What do plugs look like? Have you tried adjusting air screw or slides? :cheers:
When you did the o-rings, did you remove the carbs?? When you installed the carbs... did you Re-install the _____ _____? Anyone want to take a guess? We all should know this answer by now. That just fits his symptoms... I'll give this one a minute...
