11AGUY Posted January 26, 2012 Report Posted January 26, 2012 Guys i took my cylinders off and am in the processes of cleaning off old gasket when I took a close look at the case studs. It looks as if the six smaller studs are striped at the top ( maybe 1/4 inch). The bigger studs are fine... Is this how these studs are suppose to be??? I have nothing to compare them too and my cylinders are being bored out right now... Quote
Motooutcastxxx Posted January 26, 2012 Report Posted January 26, 2012 As long as a nut threads on and tightens up you should be good... Quote
lms1977 Posted January 26, 2012 Report Posted January 26, 2012 they are like that so the nut starts easier Quote
11AGUY Posted January 26, 2012 Author Report Posted January 26, 2012 Thx guys... What about dowel pins??? I have one on the case around a stud...is there 1 per cylinder??? Quote
Motooutcastxxx Posted January 27, 2012 Report Posted January 27, 2012 There should be 2 per cylinder and they're located on the inside studs... Quote
11AGUY Posted January 27, 2012 Author Report Posted January 27, 2012 There should be 2 per cylinder and they're located on the inside studs... Thanks..... Quote
11AGUY Posted February 23, 2012 Author Report Posted February 23, 2012 has anyone had a problem with the cylinder dowel pins. I have two that are rusted and warped and won't alloy the cylinders to seat properly. unfortunately one of them is stuck in the bottom of the right cylinder. I put the cylinder onto the piston and slid it down and it wouldn't seat. dowel pin appears to be bent and won't slip into hole at the base of the stud.... pick up two tomorrow from the stealership, just wondering if this is common......????? Quote
