hey what size are the front drag rim skinnies people running i need to order a set.
It all depends on your spindle set up!
If ur running stock spindles you can run a 10x3 Or 10x4 and if u don't run a hub you can run the same size but in a spindle mount
If ur running a 5/8th drag spindle u can run a 10x2 spindle mount!
Wt front end setup are you running?
its the stock hubs
  • 3 weeks later...
