11AGUY Posted January 16, 2012 Report Posted January 16, 2012 Guys is this hole suppose to be there.??? Next to radiator and exhaust. Same hole in the exact same shape on both sides.. Looks like it might be how it was welded at factory?? Not sure though.. Quote
06specialedition Posted January 16, 2012 Report Posted January 16, 2012 Guys is this hole suppose to be there.??? Next to radiator and exhaust. Same hole in the exact same shape on both sides.. Looks like it might be how it was welded at factory?? Not sure though.. Pics? Quote
11AGUY Posted January 16, 2012 Author Report Posted January 16, 2012 here is another shot of where its Quote
willaduncan Posted January 16, 2012 Report Posted January 16, 2012 That is not supposed to be like that, just grind the rust down and reweld both sides if you dont weld take it to a local shop shouldnt cost more than 60 bucks to weld those 2 small spots good luck man Quote
Coupelx Posted January 16, 2012 Report Posted January 16, 2012 That is not supposed to be like that, just grind the rust down and reweld both sides if you dont weld take it to a local shop shouldnt cost more than 60 bucks to weld those 2 small spots good luck man its supposed to be like that. a shit move on yamahas part because they fill with water. I drill a small hole at the bottom as a drain. Some of the stuff that comes out is nasty! Quote
willaduncan Posted January 16, 2012 Report Posted January 16, 2012 its supposed to be like that. a shit move on yamahas part because they fill with water. I drill a small hole at the bottom as a drain. Some of the stuff that comes out is nasty! It aint like that on my bike??? maybe the previous owner welded it up but it looks like a factory weld Quote
