Having Jetting probs. Meth 39 pwk Keihen carbs. Fuel leaking back into the filters. Anyone know?
Flo, it is common for drops of alcohol to spit back a little on the filters. It isnt a ton so if you have a lot then you may have a reed issue like the reeds not sealing against the cage which can be fixed by replacing them or flipping the petals over so they seal against the cage. You could alao have a cracked, broken, reed or worn edges if they are carbon fiber petals like vforce. Hope this helps. Radar
