NJ2STROKE Posted January 6, 2012 Report Posted January 6, 2012 Still new to this jetting thing. My setup is in my sig. Ok so here goes, I went up from the 160 main that came in the carb to a 170 main. Bike idles fine, so i didn't mess with the pilot. Prior to the change it would bog out at 3/4 throttle in 3rd, now it will run through all the gears full throttle, but it hesitates when from 1/2 to WOT. I haven't messed with the needle yet, wanted to change one thing at a time. The needle is on the 2nd to last clip. Do I need to move it? If so in which direction? I don't want to feel like I wasted my money on the single carb set up, and have to buy more carbs. I have been trying to get this bike right for about a month now and I feel like I'm almost there just need some more help. Thanx Quote
sleeper06 Posted January 11, 2012 Report Posted January 11, 2012 You need to do a plug chop to establish your main then play with the needle to adjust the throttle range your having a prob with.With a single carb the needle is a very important adjustment but it wont mean shit unless your main is close Quote
NJ2STROKE Posted January 11, 2012 Author Report Posted January 11, 2012 You need to do a plug chop to establish your main then play with the needle to adjust the throttle range your having a prob with.With a single carb the needle is a very important adjustment but it wont mean shit unless your main is close I dont have a vice to do a plug chop, but i think i might have it right. I left the 170 in and moved the clip to the 3rd position. The lag is almost gone, but it is hard to tell since i cant really get it wide open where I'm at. I will check it this weekemd in NJ. I will also do a plug chop while I'm there and get some more jets. Thanx Quote
