I just did a major overhaul on my banshee. 4mil stroker, lightened flywheel, flotek aggressive trail port, and timing plate. I set the timing plate on +2. But everyone seems to be going +4 with them. So what I want to know is should I go back in and change it to +4 ? And also what should I set my pickup gap at?
coolhead with stroker domes as well
try +2 and 4 see what u like better..also set your pick up gap to the size of a match book/ biz card goodluck
Edited by shakar
What fuel, what cc domes, what elevation? Flotek went over all this with me when I had him do my setup.. your pickup should be .018-.020 " be sure and use some loktite on these screws I just had a problem with them comming loose on me. Chances are you will be fine with a 4* advance..
