126happy Posted December 11, 2011 Report Share Posted December 11, 2011 ok got a small little problem, when we were taking off the flywheel the threads got messed up so now the nut will not go on. does anyone know what the exect DIE size i would use to clean up the threads?? we think its 12x1.25, no one i know has that size so we are gonna have order it so i thought id ask on here so i order the right one. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted December 11, 2011 Report Share Posted December 11, 2011 ok got a small little problem, when we were taking off the flywheel the threads got messed up so now the nut will not go on. does anyone know what the exect DIE size i would use to clean up the threads?? we think its 12x1.25, no one i know has that size so we are gonna have order it so i thought id ask on here so i order the right one. Happy it is M12X1.25 Quote Link to comment Share on other sites More sharing options...
126happy Posted December 11, 2011 Author Report Share Posted December 11, 2011 Happy it is M12X1.25 ok thx 'Picklez&Beetz', thx for the help!! Quote Link to comment Share on other sites More sharing options...
knelson Posted December 12, 2011 Report Share Posted December 12, 2011 sounds like you could use a thread file in the old toolbox. Quote Link to comment Share on other sites More sharing options...
THE358BANSH Posted December 12, 2011 Report Share Posted December 12, 2011 ok thx 'Picklez&Beetz', thx for the help!! Dont bother with a die, it can do more damage than good. Pick up a thread file for Imperial and Metric and you will never be let down... http://www.webbikeworld.com/motorcycle-tools/thread-file/thread-file.jpg http://www.webbikeworld.com/motorcycle-tools/thread-file/metric-thread-file.jpg http://www.webbikeworld.com/motorcycle-tools/thread-file/correct-fit-thread-file.jpg Quote Link to comment Share on other sites More sharing options...
126happy Posted December 12, 2011 Author Report Share Posted December 12, 2011 we tried the file and we even tried taking two rows of thread off and it still will not go on....rrrr. Quote Link to comment Share on other sites More sharing options...
126happy Posted December 12, 2011 Author Report Share Posted December 12, 2011 ok now i see what file yall r talking about. yeah i have to agree i think the thread file would be better then the die. thx for the tip!!!! Quote Link to comment Share on other sites More sharing options...
knelson Posted December 12, 2011 Report Share Posted December 12, 2011 (edited) The problem with using taps and dies to fix threads is that it usually undercuts/removes the threads and makes the tolerances sloppy. Try a thread restore kit that straightens the threads and you will be much happier. Edited December 12, 2011 by knelson Quote Link to comment Share on other sites More sharing options...
camatv Posted January 31, 2012 Report Share Posted January 31, 2012 the end of the shaft is probably mushroomed. did you use the proper puller when you took the flywheel off?> or a 3 jaw backwoods chevy harmonic dampner puller?? if you used one of those i'm pretty sure you also damaged the flywheel as well. might be time for a new crank end and a new flywheel. good luck! Quote Link to comment Share on other sites More sharing options...
