252wheelieking Posted November 20, 2011 Report Posted November 20, 2011 I am currently building a 421 cub & was wondering what size domes & timing you guys recommend for 93 pump gas at sea level. I have read on here that 24cc domes are a good set of domes to use at that elevation. My set-up will be SB IF Shearers, Chariot coolhead, 421 cub of course, VF2's, 34mm PJ's & dual K&N filters. I am using the bike to play around with. Im not all into drag racing but will drag race sometimes for fun. Thanks for your opinions in advance. Reek Quote
Coupelx Posted November 20, 2011 Report Posted November 20, 2011 have a sponsor make you some domes. Quote
werner Posted November 20, 2011 Report Posted November 20, 2011 I just got my custom domes from Redline. Quote
Sandfrk33 Posted November 20, 2011 Report Posted November 20, 2011 I think HJR cut my domes to 23cc for pump gas. My timing is at +4. Runs a little warm, but nothing alarming Elevation here is 1000 to 2000 Quote
werner Posted November 21, 2011 Report Posted November 21, 2011 always check your squish too. Redline send me a set after we discussed what my setup was, what kind of riding whati wanted to do with it, how much i weighed, base gasket or not, etc.... he told me to put them in and do a squish test. if it wasnt correct he would send me a new set along with a package to send the others back. Quote
252wheelieking Posted November 21, 2011 Author Report Posted November 21, 2011 I think HJR cut my domes to 23cc for pump gas. My timing is at +4. Runs a little warm, but nothing alarming Elevation here is 1000 to 2000 At what temp is your shee running at that you consider warm with those domes & timing? Quote
252wheelieking Posted November 21, 2011 Author Report Posted November 21, 2011 always check your squish too. Redline send me a set after we discussed what my setup was, what kind of riding whati wanted to do with it, how much i weighed, base gasket or not, etc.... he told me to put them in and do a squish test. if it wasnt correct he would send me a new set along with a package to send the others back. what is your dome size, squish, timing, base gasket thickness, type fuel, & set-up? Quote
sleeper06 Posted November 21, 2011 Report Posted November 21, 2011 why wouldnt get the whole set-up from one guy so there is no question,22-23cc domes depending on porting,+4 timing is the max on pump fuel but is sometimes too much depending on variables so i have run as lil as +2,squish i like at .050,order diffrent base gaskets to adjust squish Quote
252wheelieking Posted November 21, 2011 Author Report Posted November 21, 2011 (edited) why wouldnt get the whole set-up from one guy so there is no question,22-23cc domes depending on porting,+4 timing is the max on pump fuel but is sometimes too much depending on variables so i have run as lil as +2,squish i like at .050,order diffrent base gaskets to adjust squish What up sleeper06? I am getting the complete set-up from Kevin at HJR. I just wanted to hear some different opinions on other set-ups. Thanks for the info, it really helps out alot. I am getting a clean-up port. What base gasket thickness is good for 22-23cc domes? What variables would cause +4 timing to be too much?. I have not heard from you in a while. I was going to get you to do my stockers but couldn't keep in touch with you. Edited November 21, 2011 by 252wheelieking Quote
bansheeryder21 Posted November 21, 2011 Report Posted November 21, 2011 call Kevin at HJR. www.herrjugsracing.com I would think 21cc domes with +4 timinng. That's what I run on 91 pump gas look at my sig for my motor. Not sure how different cubs are. Quote
252wheelieking Posted November 21, 2011 Author Report Posted November 21, 2011 call Kevin at HJR. www.herrjugsracing.com I would think 21cc domes with +4 timinng. That's what I run on 91 pump gas look at my sig for my motor. Not sure how different cubs are. We have the same exact set-up for stock cylinders. It's a little different with the cub. Did you read my sig? Thanks tho. Quote
bansheeryder21 Posted November 21, 2011 Report Posted November 21, 2011 We have the same exact set-up for stock cylinders. It's a little different with the cub. Did you read my sig? Thanks tho. sorry I didn't read your sig. That's cool we have the same set up. Eventually I want to up to a cub as well. Where do you ride? Im asking because I notice your gearing is way different then mine. I ride at glamis/gordons sand dunes and can pull 4th gear up any hill. Wondering if I should go up to a 15t front? Quote
252wheelieking Posted November 21, 2011 Author Report Posted November 21, 2011 (edited) sorry I didn't read your sig. That's cool we have the same set up. Eventually I want to up to a cub as well. Where do you ride? Im asking because I notice your gearing is way different then mine. I ride at glamis/gordons sand dunes and can pull 4th gear up any hill. Wondering if I should go up to a 15t front? I ride wide open fields, down country backroads & long paths through the woods. I tried running a 14/40 but I run out of gear to fast. A 16T front sprocket is a bit much & a 15T would be perfect for me but im keeping the 16 for the 421 cub. Are you at sea level cause it's funny I use the same jetting 52 pilots CEG needle mid clip & 158 mains 75+ degrees. Edited November 21, 2011 by 252wheelieking Quote
bansheeryder21 Posted November 21, 2011 Report Posted November 21, 2011 I ride wide open fields, down country backroads & long paths through the woods. I tried running a 14/40 but I run out of gear to fast. A 16T front sprocket is a bit much & a 15T would be perfect for me but im keeping the 16 for the 421 cub. Are you at sea level cause it's funny I use the same jetting 52 pilots CEG needle mid clip & 158 mains 75+ degrees. Im at sea level. You think im too rich? Quote
werner Posted November 21, 2011 Report Posted November 21, 2011 what is your dome size, squish, timing, base gasket thickness, type fuel, & set-up? My setup is 15:1 comp with .45 squish, +4 timing, no base gasket on full race 110. I suggest staying with builder for most components. I purchased my topend and clutch setup from Redline so I had domes cut to what he recommended for me. Quote
