HI ALL
Just checking if I should go up one or two size in my jetting for a set of small bore CPI in-frame. I just switch from FMF gnarly pipe with toomy sileners to a set of CPI. My list of mods are in my Signature below. My jetting is 50 on the pilot & 158 on the mains. I ride at Sea Level. The bike jetting was spot on with the FMF.
Thanks for any input,
WFO
I would say try it out the way it is. I use to have a dune port with 28mm PWK, pod filters, CPI inframes, and I was running a 158 main 48 pilot. So give it shot they there already jetted then go from there.
HI ALL
WFO
My set up is similar to yours exept that im on 35's
158 main 55 pilots also at sea level in Cali also on CPI pipes
