mikey7o2 Posted November 1, 2011 Report Share Posted November 1, 2011 im trying to find out what size keihin carbs i have there is a number on one side that says 29sbonjm does any one no what that means ? Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted November 1, 2011 Report Share Posted November 1, 2011 Measure the smallest diameter of the throat where the slide goes up and down , use an inside Mic if you have one or can even eye ball it with a tape measure or what have you... Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted November 1, 2011 Report Share Posted November 1, 2011 Measure the smallest diameter of the throat where the slide goes up and down , use an inside Mic if you have one or can even eye ball it with a tape measure or what have you... long time no see, did Julian lock the shed on ya? Cody Quote Link to comment Share on other sites More sharing options...
Starwriter Posted November 2, 2011 Report Share Posted November 2, 2011 29s should be a 28mm PWK. http://www.sudco.com/pwk.html It should look like this, with 2 screws holding the cap on top. This pic also gives the outside dimensions. http://www.sudco.com/CatalogJPG/046.jpg Quote Link to comment Share on other sites More sharing options...
