smokin 2 stroke Posted October 30, 2011 Report Posted October 30, 2011 im building my buddies banshee for him he wanting it be a 10 second banshee in the 1/4 miles... what kind of motor should i be looking at building. im new to building drag motor so im not sure of whats the best combo. im have about 3 grand to work with. i was thinking of a 7 mil cub ? Quote
CFH87 Posted October 30, 2011 Report Posted October 30, 2011 If your having cases trenched go with a 10mil cub run it on alky... Quote
BigRed350x Posted October 30, 2011 Report Posted October 30, 2011 3k isn't much of a budget for a good fast bike. A good start would probably be a 10mil cub, straight-cut gears, billet basket, override trans, vforce reeds, cool head, timing plate, alky carbs, lockup clutch, good pipes... That right there is probably going to murder your 3k budget and might not get you where you want to be. Quote
smokin 2 stroke Posted October 30, 2011 Author Report Posted October 30, 2011 well i have 3k to put towards just the motor, i know i will have work on the chassis and such but thats going to be different budget and topic. with 3k what the most i can get including exhaust and carbs Quote
BigRed350x Posted October 30, 2011 Report Posted October 30, 2011 well i have 3k to put towards just the motor, i know i will have work on the chassis and such but thats going to be different budget and topic. with 3k what the most i can get including exhaust and carbs Not a 10sec setup. LOL Cub cylinders will be the cheapest aftermarket cylinder you can get that would give you the performance you're looking for. They are around $8-900. A 4mil crank is about $450-500, a 10mil crank is around $1k, cool head is $200, reeds are $200, good alky carbs will run you anywhere from $350-500 depending on who does them and what kinda options you get on them, pipes will put you back $350-700 depending on which ones you go with and if you get chrome or bare metal, lockup & cover is about $350, straight-cut gears are about $300-350, billet basket is about $150-200, or you can get the spring-loaded billet basket/straight-cut gear combo for $600, intakes are $100-150, a good override will run ya around $350-400. Then you will have all the misc odds and ends to get it all put together right. Give Kevin @ HJR a call. He can hook you up with any of the stuff above & get you a good bang for your buck. Great guy to deal with and fast turnaround time. His number is in my sig. - Jared Quote
CandyBansh Posted October 30, 2011 Report Posted October 30, 2011 Or you can save that money and buy my 10mil super cub drag bikefor a fraction of the cost and I run 9.90s in the quarter mile. Quote
camatv Posted October 30, 2011 Report Posted October 30, 2011 good luck. this isnt a budget sport.. although time is free Quote
dirtydownunder Posted October 30, 2011 Report Posted October 30, 2011 build a banshee in 10 seconds maybe ? Quote
