alexd2 Posted October 29, 2011 Report Posted October 29, 2011 While I was riding my clutch suddenly stopped working. I rode it home and when I looked the actuator arm was popped out and jammed into the carburetor. Not sure what to do or how to fix it. Any suggestions? Quote
notsed Posted October 29, 2011 Report Posted October 29, 2011 sounds like the tab that hold it in fell off if you need pics of how it should be let me know, youll have to take the clutch apart and pull the push rod out of the shaft to get the actuater back in Quote
BigRed350x Posted October 30, 2011 Report Posted October 30, 2011 Check the bottom end assembly walkthrough in my signature. It will show you how it all goes together and give you an idea of where to start checking stuff... I'd be willing to bet that your clutch is out of adjustment and your missing the keeper on the top of the arm. Might be time to pop the clutch cover off and check things out. The clutch accuator arm also has a little tab that gets bent down to hold the cable in place, that might be broke off on yours. - Jared Quote
