4MiLLDraGSheE Posted October 14, 2011 Report Posted October 14, 2011 Im thinking im gunna step up to a 10 mill cub now. These are stock cylinders at 64.5mm bore with a 4mm trued and welded crank. I bought this settup from NYUK dune portedabout a year ago and sent them to Kevin to have them full drag ported. And then got everything polished. This is a feeler i havent removed anything yet but pistons are good noss machine cool head with alky domes everything polished very nice. Ive ran this engine through heat cycles and about three trips up and down the driveway and the thing hauls theres not even thrity minutes run time here. Let me know if you have any questions. As for prices id like 300 for the crank. 550 for the Cylinders domes pistons rings. I can sell the noss machine head if someone is interested but i would like to use with the cub. Thanks! Quote
dannie Posted October 15, 2011 Report Posted October 15, 2011 Do u have any pics of the 4mil crank Quote
DwnSouth Posted October 15, 2011 Report Posted October 15, 2011 Do u have any pics of the 4mil crank What size bore? Full drag ported for what fuel... Pump gas, race gas, alky? Quote
4MiLLDraGSheE Posted October 15, 2011 Author Report Posted October 15, 2011 Its full drag ported and on alky. Changing the fuel will require new domes and different timing. No pictures of crank as i didnt take any before it went in. Engine is still all together but the cranks in there. Quote
chrisp250r Posted October 15, 2011 Report Posted October 15, 2011 Its full drag ported and on alky. Changing the fuel will require new domes and different timing. No pictures of crank as i didnt take any before it went in. Engine is still all together but the cranks in there. what brand is the crank, and are the rods 110 or 115mm? Quote
4MiLLDraGSheE Posted October 15, 2011 Author Report Posted October 15, 2011 what brand is the crank, and are the rods 110 or 115mm? Hot rods, long rod so 115mm Quote
SandmanPNW Posted October 15, 2011 Report Posted October 15, 2011 Hot rods, long rod so 115mm pm sent Quote
