hey guys i got this banshee from some ass clown that doesnt know anything about it and now i cant even get ahold of him but the ? is the clutch was welded when i got it so i had to split the case and change the rod ball and pancake bearing now that it is put back together it has no throttle it start easy as hell and idles great but no rev.!! the carbs are aftermarket mikuni with flat slides no tors or parking break are even on the machine. i brought it to a guy who said the carbs are set up for alcohol but why wouldl it run fine before i changed the clutch rod????
You need to provide more details of the carbs, are you trying to run it on gas or alky, etc...
i want it to run on gas and it did when i got it after i changed the clutch it wouldnt rev up you can start it it idles perfect you can even put it in gear and drive but with no throttle the carbs on it now are 35mm mikuni d slides. i just dont get why it ran good with no clutch and now it runs like shit
  • 2 weeks later...
if you are pushing the throttle and nothing is happening then the slides arent opening. Pull the filter and push the throttle anl look to see if slides are moving
the slides work fine it just pours raw fuel in so it floods out thats what i mean by no throttle the main jets are 180
you got some pretty sick toy good taste as well i just got rid of my bike kx250 2001
Well if the carb are set up for alky that is what it will do flood the motor out on gas. Check the jets you stated 180 but is it realy 180 or did the ass clown drill it out to make is own alky jet? When you buy a banshee from a ass clown you will need to go back to basics for checking shit out.
We will need more info on your set up to give the best help.
