cav4ever Posted September 18, 2011 Report Posted September 18, 2011 I have owned my very first banshee for 2 months now and the silences on the left side has a ton of oily residue around the exhaust hole the right side has none to very little and then I pulled the plugs the left side plug looked like it was real rich and the right side was dry looking but you could see its firing just not covered in oil like the left plug any ideas would be helpful Quote
Larry's Shee Posted September 18, 2011 Report Posted September 18, 2011 to high of float level, maybe. Check that you have same jets in both carbs, same air screw and needle settings Quote
06specialedition Posted September 19, 2011 Report Posted September 19, 2011 Check carb sync as well. Quote
cav4ever Posted September 19, 2011 Author Report Posted September 19, 2011 I was just reading up on carb sync I still have the tors on mine I am gonna change that during the winter so when I sync the carbs where do I make the adjustment at to get them synced all articles I have found are syncing with the tors removed Quote
cav4ever Posted September 20, 2011 Author Report Posted September 20, 2011 Ok found right side slide moving 1/8" before the left I have tors still hooked up where do I make the adjustment at to fix this Quote
