amstall Posted September 18, 2011 Report Posted September 18, 2011 Here is a list of what the extra bike comes with: Frame -Vin JY43GG0385C059247 (yr 2005) -Broke and rewelded grab bar mounts -1 Rear Fender Mount missing -Heal Cup mount missing -Rear Shock mount has been rewelded -Chain roller included Motor The crank is siezed but the output shaft spings freely. The lower case half is cracked on the clutch side, and the upper on the stator side( dry area, doesn't effect anything). The cylinders have been bored once (20 over) Clutch side cover is missing. The cylinders alone are worth almost $100 on bansheehq.com -1 Good head -1 Head damaged dome one 1 side FMF Fattys -Surface rust -No dents or dings -would be perfect if powder coated 2 Complete clutches -basket -inner basket -pressure plate -disks Swing Arm -Needs rewelded A-Arms -1 upper bent -ball joints appear to be good Front spindles Front Rotors Tie Rods (not bent) Front shocks (condition unknown) Rear Shock (told it was blown, never used personally) 2 TORS Kits Stock Headlights Kicker 2 Rear Sprockets -1 good Sprocket Hub Front Sprocket Chain (condition unknown) Rear Rotor and Hub Pivot Bolt Chain Tensioner Bearing Carrier Axle Nuts All Radiator Hoses Coolant Bottle Shift Lever rear Brake Lever Lower Front fender mounts Pegs & Heal Cups Rear Brake light switch headlight/run switch cluster Thumb Throttle Coil and Plug Wires 2 front calipers w/ pads front brake lever front stock bent steel brake lines Front Brake T- and Hose Rear master cylinder, Caliper, Resivoir, and pads Stator Cover -Cracked 2 Stock Carbs (1 L, 1 R) Oil filter cover Kick Gear 2 boost bottles 2 reed cages w/ reeds 2 intake boots -1 cracked radiator Air box w/ 1 into 2 boot Gas tank w/ petcock asking $1000, make an offer. Message me with questions Quote
