  • Replies 72
  • Created
  • Last Reply
Top Posters In This Topic
Still have complete engine, modquad head (21cc), Toomey T5s, +4 swingarm, 3 bar bumper, VForce Reeds, Chrome steering stem, wheels, alot of plastics, And alot of stock parts... Rear shock, spindles, hubs,
heres what i have left
Lsr +4 Swingarm, pc silvervein some of the powdercoat is chipped off. Its solid no cracks or repairs. Comes with longer chain. $225
Full Toomey T5 exhaust system (pipes and silencers) Good overall shape normal chrome wear up near cylinders. 225
Douglas front rims nice shape Straight, few little dings on outer lips from trail riding. $50
Chrome steering stem stock height. $60
seat custom cover orange/checker $50
Complete bottom end, Good stock crank and tranny, also Comes with flywheel and good stator with both covers. No leaks. Cases are good they have the normal little chip missing from the chain. $300
Cylinders 64.5mm Good bore/crosshatch ( only .5mm over stock Means lots of bores left in them) $225
Complete clutch , basket plates everything $50
Stock radiator $10
Thumb Throttle assembly (tors plug cut off) $10
Intake boots with crossover tube $10
Chrome spindles with front wheel hubs and rotors Good bearings. $50
Rear wheel hubs $40
Brake hub and rotor rear, rotor shows some wear but still useable $10
Axle carrier Good bearings $50
Stock rear wheels with 1/2 tread tires (few plugs) $50
Orange tank cover and grill plastic $30
Black maier front fenders factory race cuts, and black radiator/grill plastic $40
Rear plastic (painted black) $20
Front plastic cut (painted black) $20
Red front plastic with tank cover and grill/radiator plastic $40
Blue tank cover $10 (cpl stress marks)
Stock seat needs recovered $10
HEadlight/ run switch works good small peice of Hi/Lo headlight switch broke off still enough there to use $10
Misc hardware/parts lot Shifter, Pipe hangers, chain adjusters, steering stem clamp/bushing, headlight mounts, engine mounts... all for $20
