f4istunna Posted September 15, 2011 Author Report Posted September 15, 2011 Axle is Sold. Sale pending on wire harness, airbox, and ignition switch Quote
spalding Posted September 16, 2011 Report Posted September 16, 2011 can i get some pictures of the toomey exhaust sent to [email protected] thanks Quote
f4istunna Posted September 16, 2011 Author Report Posted September 16, 2011 ill send pics of exhaust shortly wiring harness, ignition switch, airbox, and footpegs are sold. Quote
f4istunna Posted September 20, 2011 Author Report Posted September 20, 2011 Frame, Oversize tank, protaper bars, Case saver, front and rear brake systems, and ohnins shocks Sold Quote
f4istunna Posted September 22, 2011 Author Report Posted September 22, 2011 Still have complete engine, modquad head (21cc), Toomey T5s, +4 swingarm, 3 bar bumper, VForce Reeds, Chrome steering stem, wheels, alot of plastics, And alot of stock parts... Rear shock, spindles, hubs, Quote
armyvet Posted September 23, 2011 Report Posted September 23, 2011 what kind of shape is the rear shock in ?the shee i just picked up is leaking a bit on the rear seal..jermaine Quote
f4istunna Posted September 23, 2011 Author Report Posted September 23, 2011 rear shock is good man, Ill email you a pic of it later this afternoon. or just call/text me if you just want to see it. rob Quote
f4istunna Posted September 29, 2011 Author Report Posted September 29, 2011 heres what i have left Lsr +4 Swingarm, pc silvervein some of the powdercoat is chipped off. Its solid no cracks or repairs. Comes with longer chain. $225 Full Toomey T5 exhaust system (pipes and silencers) Good overall shape normal chrome wear up near cylinders. 225 Douglas front rims nice shape Straight, few little dings on outer lips from trail riding. $50 Chrome steering stem stock height. $60 seat custom cover orange/checker $50 Complete bottom end, Good stock crank and tranny, also Comes with flywheel and good stator with both covers. No leaks. Cases are good they have the normal little chip missing from the chain. $300 Cylinders 64.5mm Good bore/crosshatch ( only .5mm over stock Means lots of bores left in them) $225 Complete clutch , basket plates everything $50 Stock radiator $10 Thumb Throttle assembly (tors plug cut off) $10 Intake boots with crossover tube $10 Chrome spindles with front wheel hubs and rotors Good bearings. $50 Rear wheel hubs $40 Brake hub and rotor rear, rotor shows some wear but still useable $10 Axle carrier Good bearings $50 Stock rear wheels with 1/2 tread tires (few plugs) $50 Orange tank cover and grill plastic $30 Black maier front fenders factory race cuts, and black radiator/grill plastic $40 Rear plastic (painted black) $20 Front plastic cut (painted black) $20 Red front plastic with tank cover and grill/radiator plastic $40 Blue tank cover $10 (cpl stress marks) Stock seat needs recovered $10 HEadlight/ run switch works good small peice of Hi/Lo headlight switch broke off still enough there to use $10 Misc hardware/parts lot Shifter, Pipe hangers, chain adjusters, steering stem clamp/bushing, headlight mounts, engine mounts... all for $20 Quote
meddle636 Posted October 3, 2011 Report Posted October 3, 2011 Can you send me pics of the clutch basket fingers? Also is the front bumper still for sale? Quote
f4istunna Posted October 3, 2011 Author Report Posted October 3, 2011 clutch is in great shape good basket, no grooves. I have a sale pending on it though., and another guy in line for it Quote
bansheerilla Posted October 3, 2011 Report Posted October 3, 2011 Can u send me pics of all the plastics u have please. Very interested. Quote
bansheerilla Posted October 3, 2011 Report Posted October 3, 2011 Sorry u can send those pics to [email protected]. Quote
Vtbanshy Posted October 5, 2011 Report Posted October 5, 2011 Do you still have the stock radiator and shifter? Quote
