i bought my first banshee rode it like maybe 4 time and the left piston blew up. I pulled off the jugs and seen that it has a hot rod cranke. the numbers on them is c.k. 158 B. can anyone tell me if its a long rod crank or if its normal stroke lenth so i can order my pistons
4 times? really? i thought you said 2 times in your other EXACT same post that you made.
Little BHQ tips to get more help on here.....
-dont repost things....it pisses us off and makes less of us want to help you.
-also give as much detailed info as possible. "hey guys i have a 2001 banshee with a non-welded crank and i split the cases cause i melted pistons when i rode it hard....i think its a jetting issue and i want to know what kind of crank i have in here" you're gonna get more if you describe shit.
but if you are serious about wanting to find out what rod you have you could call wiseco.....or the easier way would be to put one jug back on and measure how far up the down the stroke is.....then you have found the answer to your problem.....and it'll take minutes....not 2 days
Maybe its both a long rod stock stroke crank? Connecting rod length and linear stroke are two different terms. Best bet is to contact the manufacturer. They can give you the tolerances and specs so that you can measure it out. I would go over every part of the rotating assembly every time one of the parts fails. There might have been an odd stress on the crank during failure.
  • 2 weeks later...
just gocall hot rod. i mean you got the number on the rod just google or go to the web site thats what i did.
Thanks for the help and sorry for posting twice! I'm posting by phone so want sure it went through
