just get the small one. the one i have costs about 20 bucks to refil and i think the tank cost 80. i have filled about 20 shocks iwth it so far your not using much. i also have mine on a lil cart to roll it around..
i have no idear what the size of tanks is i honestly go in and say i need that one..
if i rember right i think 20 was what i rember. its smaller than the one on my MIG. about the size of the ones that come on those small portable gas torch's
What is a good average size tank for home use? I don't want to get one that's so small that I fill 4 shaws and it's empty, but I also don't want to pay for a tank that will fill 500 shocks.
My portable tank is a 60cuft. Stands about two feet tall, 10in in diameter. With a Goss 0-1500psi regulator. I wouldn't get any smaller than a 60. You will find other uses for it. Car tires in a pinch, especially. Any reputable welding supply place does exchanges, on bottles. Take in your empty, get a full one on the spot. It costs me $13 to swap out my 60, and they deliver my 255cuft for the shop for 65.
Thanks for the help. I went to the welding supply place and they stock 20, 40, 92... I decided 92 was overkill (and $185), so I settled for the 40 at $115. I already have a couple of 5 lb aluminum co2 tanks with regulators that I use for airing up tires and stuff. You can air up a LOT of tires with 5 lbs of co2.
Just FYI, c02 and nitrogen use different fittings. The regulators aren't compatible.
