Hi guys
Before starting my banshee today I checked all the fluids.I see the coolant was low so topped it up.After doing so, I noticed coolant leaking under the engine. It appears to be coming from the area where the coolant hose comes out from behind the clutch cover . The coolant is running along the back of the heads on the top of the block and down through. The hose isnt cracked, clamp is tight...any ideas
clean it down, pressure test it or start it up. and wait for it to leak, check both sides of the pipe and around the head.
check you trans fluid, make sure there isnt any water in there. (there is a oring on the end of that coolant pipe, that sits inside the clutch cover)
