My banshee leaks by clutch cover
Justin k
Prop up the rear end. Dry off everything good. have a friend sit on the quad and run it. pull the clutch shift gears and sit there until you see where its coming from. Like zilla said oil or coolant would help top narrow it down possibly
Yes its oil i bought a new gasket and put it on right i think its the drain plug is there a o ring on it or something on drain plug i havent had time to mess with it i have a skid plate under motor so its hard to tell have to take it off one day. Could it be the carbs leaking the left over gas in them?? it only leaks after i ride it
