goat2005 Posted August 8, 2011 Report Posted August 8, 2011 port done by rdz rdz oofs lean on one side melted plug other side rich as hell fouling plug is +6 timing good enough or more rdz is no help he says he dynoed but doesn't have dyno sheet please need help Quote
slag_350300 Posted August 8, 2011 Report Posted August 8, 2011 Sounds like an air leak. Bad crank seal maybe. What side is running lean? Spray the ignition side crank seal with wd40 while it's running and if the rpms fluctuate you have a bad seal. Or do a leak down test to see if it's elsewhere Quote
camatv Posted August 9, 2011 Report Posted August 9, 2011 you need to do a leakdown test.. if RDZ did the whole motor you better send it back. Quote
