SuprSlow50 Posted August 6, 2011 Report Posted August 6, 2011 Complete MSD setup for Banshee, replaces stock CDI and coil, comes with MSD box and coil, two six cell batteries, and battery charger. It allows different (variable) timing curves to your machine. Has a holeshot rev limiter, and adjustable timing curve via switches you can flip inside the box. It allows 21-28 degrees of initial timing, and retards the timing between 8-15 degrees starting at 4000rpm. Here is some of the info from MSD's webpage... Includes everything needed to run and it is very easy to install. Will have pictures tonight. $375 shipped http://www.msdignition.com/instructions/Products/4204.pdf?terms=4204 Adjustable Ignition Timing Curve: The MSD Enhancer Ignition system allows you to program an ignition timing curve. Changes in altitude, compression, fuel octane or a number of other variables requires that the ignition timing be compensated. The MSD Enhancer allows you to advance or retard the initial timing as well as designate a different timing curve to increase overall power and performance. Holeshot Feature: The feature allows the user to program an rpm-limit, which enables the rider to leave the starting line quicker. Quote
