Hey guy's looking for a little input. been putting my new motor together today and get to the point to put the piece on that holds the transmission bearing in. After torquing it i turn the tranny to find a little stick in one spot. it spins nice but in one spot it's like it hangs up. if you spin it kinda fast it's not as noticible but when spinning it slowly it's really noticible it will stop in that spot what do you guy's think should I just tear it down and investigate? I would rather be safe then sorry
If you haven't put the top case on, I would inspect ALL your gears for burrs, nicks or other damage. You also might try cleaning the bearings with some brakeclean and air and then lightly oiling them. It sounds like it is catching when you are just spinning the tranny, not shifting. If that is the case, I would not put it together until it is right. If the problem is while you are trying to shift, you need tosopin things so the dogs will line up and engage.
if the top half of the case is not on it will bind up, i had this same thing happen when my upper case half was off while trying to spin my gears.
