bennny Posted July 23, 2011 Report Posted July 23, 2011 Well, as I was installing mine I was noticing that the "o-ring" is just a cheap foam deal. I put a little grease around it to help it seal and put it on. My question is, has anybody had a problem with dust and what not getting by that? It doesn't seem like a very good seal, so I was just wondering if anyone puts gasket sealer or anything else around it instead of just relying on the foam o-ring that comes with it. Quote
Banshee Chad Posted July 23, 2011 Report Posted July 23, 2011 Talking cool head or pro flow filter adapter? If air filter adapter I gobbed silicon on there too! Quote
bennny Posted July 23, 2011 Author Report Posted July 23, 2011 Talking cool head or pro flow filter adapter? If air filter adapter I gobbed silicon on there too! It's for the air filter adapter.....I was kind of thinking I should put some gasket material on it Quote
Banshee Chad Posted July 23, 2011 Report Posted July 23, 2011 It's for the air filter adapter.....I was kind of thinking I should put some gasket material on it Not sure how gasket material would do, but silicone works great. Quote
bennny Posted July 23, 2011 Author Report Posted July 23, 2011 I use grease on mine works great Did you just use grease? If the majority of people on here just use grease to help seal it then i'll have peace of mind. If it's common knowledge to apply silicon as well to the foam o-ring then i'm gonna want to take it apart and re-do it Quote
toytech Posted July 23, 2011 Report Posted July 23, 2011 Did you just use grease? If the majority of people on here just use grease to help seal it then i'll have peace of mind. If it's common knowledge to apply silicon as well to the foam o-ring then i'm gonna want to take it apart and re-do it I put grease on both sides of the foam gasket Quote
bennny Posted July 24, 2011 Author Report Posted July 24, 2011 I put grease on both sides of the foam gasket Yea, I figured so now i'm just irritated that I have to take it off again. I only put grease on the side making contact with the airbox, and for peace of mind I want it on both. Does anybody know of anywhere you can get a rubber o-ring for this adapter plate? I really don't like this foam setup and would be way more comfortable with a rubber o-ring. If anybody knows where to get one (or if one even exists) just let me know. Thanks! Quote
lms1977 Posted July 24, 2011 Report Posted July 24, 2011 I always use the hi temp rtv stuff the hi temp not needed that just the nd I always buy. and it never leaks. and yea the foam oring is a joke Quote
bennny Posted July 24, 2011 Author Report Posted July 24, 2011 I always use the hi temp rtv stuff the hi temp not needed that just the nd I always buy. and it never leaks. and yea the foam oring is a joke Have you ever heard of a place to get a rubber o-ring to replace the foam one? Quote
barahonapr Posted July 24, 2011 Report Posted July 24, 2011 yea i just put mine on and i also used the high temp rtv. worked great. Quote
camatv Posted July 25, 2011 Report Posted July 25, 2011 you cna buy bulk rubber mat and just cut out your own seal then silicone or import grey it all together while you hvae the box off you can seperate the other parts and seal them up also. Quote
