hi all i have a 2005 banshee and i have found latley that when i rige through mud or water the bike then begins to brake down and after about 5 min it will slowley come back up to idle
My carbs are mukuni
Tors ? Removal kit ? I don't understand
The TORS are those big switch assemblies mounted on top of your carbs. You cant miss them.
Nar I don't have them I have a set of mukuni carbs but I did go through the electric system and cut of excess wires out
Tors plugs
Light plugs
Key plug
I have been told buy some people that it might be the standard spark plug cover ( where the spark plug joins the leads ) and to fit full sealed silicone plug covers ?
I have ordered a new stator rubber seal just to make shore water is not getting into the stator
Tors plugs
Light plugs
Key plug
You must already have the delete kit.
What do you mean I must already have the kit what does this kit have ?
Yes I do have the tors replacement kit I think I will go through the electrical systerm and clean it up
