blacksnakes Posted July 11, 2011 Report Posted July 11, 2011 hi all i have a 2005 banshee and i have found latley that when i rige through mud or water the bike then begins to brake down and after about 5 min it will slowley come back up to idle Quote
blacksnakes Posted July 11, 2011 Author Report Posted July 11, 2011 My carbs are mukuni Tors ? Removal kit ? I don't understand Quote
Dicklez Posted July 12, 2011 Report Posted July 12, 2011 My carbs are mukuni Tors ? Removal kit ? I don't understand The TORS are those big switch assemblies mounted on top of your carbs. You cant miss them. Quote
blacksnakes Posted July 12, 2011 Author Report Posted July 12, 2011 Nar I don't have them I have a set of mukuni carbs but I did go through the electric system and cut of excess wires out Tors plugs Light plugs Key plug I have been told buy some people that it might be the standard spark plug cover ( where the spark plug joins the leads ) and to fit full sealed silicone plug covers ? I have ordered a new stator rubber seal just to make shore water is not getting into the stator Quote
Dicklez Posted July 12, 2011 Report Posted July 12, 2011 Nar I don't have them I have a set of mukuni carbs but I did go through the electric system and cut of excess wires out Tors plugs Light plugs Key plug I have been told buy some people that it might be the standard spark plug cover ( where the spark plug joins the leads ) and to fit full sealed silicone plug covers ? I have ordered a new stator rubber seal just to make shore water is not getting into the stator You must already have the delete kit. Quote
blacksnakes Posted July 12, 2011 Author Report Posted July 12, 2011 What do you mean I must already have the kit what does this kit have ? Quote
blacksnakes Posted July 12, 2011 Author Report Posted July 12, 2011 What do you mean I must already have the kit what does this kit have ? Yes I do have the tors replacement kit I think I will go through the electrical systerm and clean it up Quote
