i'm new to banshees, so can someone tell me what it means when its running lean,
sorry if im a newb, but dont talk sh*t
Well, then poop , crap, doo-doo :jesterlaugh: . It means unless you fix the lean condition it will melt down and blow the fuck up. banghead:cry: Causes: air leak, improper jetting, dirty carbs. Overheating can cause leanness, leanness can cause overheating. Why do you think it's lean? List symptoms and everything about your set-up and someone may help you further. :clap:
Edited by Larry's Shee
It over heats in like 10 minutes
Did it just start this or been this way since you got it? What do plugs look like?Pressure test cooling system. Pull water pump cover and plate off pump. Inspect impellor, pull spark plugs so you can roll it over easier, hold light pressure on impellor and crank with kicker felling for gear skipping. Maybe try new rad cap. :cheers:
