hey guys im located in chicago and dont really have a place to tune around my home so if anyone can throw some jeting ideas for both my steups i would appreciate it.
421 cub
68mm bore cub cyls
+7 timing
cpi sb inframes
35mm pwks (keihin)
cool head (17cc domes)
110 octane
+6 swinger
11 paddle extreme haulers
clean up port
4mil
66mm bore stock cyls
+5 timing
cpi small bore inframes
35mm pwks with oversized bowls
stock head (shaved)
110 octane
+6 swinger
10 paddle extremes
drag port
lock up clutch
elevation where we ride is around 500 above sea level.
any jetting help would be awesome.
thanks in advance
My 4mil cub with similar mods and 35 pwks has 155 main and a 48 pilot. That's around 1300 ft. elevation and I believe it is a safe jetting. You might want to start a little higher just to be safe though.
I'm about 40minutes outside of chicago and I have a 421 cub, mods in sig, but it's basically the same setup as you and I have 155main, 48 pilot, cel needle on the 3rd clip and the plugs look good. I just don't have the compression that you have, but I think you will have a very good starting point with all the jetting advice that was given already.
you guys shoudl try 45 pilots. would be a lil more snappy off the bottom. i have had to go down as low as 40's on pwk's with a cub. a 400 stock stroke i did ended up with 35 slows and 168 mains..
but always jet to what the motor wants..
I have a 4mill 421 cub with 39 pwks and 17cc domes. I run a 45 pilot and a 155 main and it runs great on the Oregon coast. I use a 40:1 mixture with VP racing c12 fuel. Its a little rich but runs good.
damn same set up on a 421 by me is 178-185 mains 52-55 pilot,what a diffrence
  • 2 months later...
