How do I replace the rods on the crank?
By splitting your cases and removing the crank to be sent to a rebuilder, who will rebuild it and true & weld it. It is not a job for a do it yourselfer at home in his garage. You can split the cases yourself.
Yep.
I have done 3 dirtbike cranks and that was not to bad you have to press the two halves apart then press it back together and then true it up it takes a machine shop.
I will not be doing my own banshee crank if it ever needs it it will get sent out to make sure it is right.
not saying you can't do it I would recommend sending it to a shop.
  • 1 month later...
Better to just buy another crank.
whats the difference in a new crank & a rebuilt one if all parts are new on rebuilt crank?
Or your saying it better far as cost issue? :shrugani:
Edited by 252wheelieking
