5.0bronco Posted June 7, 2011 Report Posted June 7, 2011 will yfz450 shocks work with full flight +2 +1 a arms? Quote
vifferman Posted June 7, 2011 Report Posted June 7, 2011 Full flight makes a arms for banshees and 450 shocks but most of them are +3. If they make them you can probably find them on E-bay Quote
5.0bronco Posted June 8, 2011 Author Report Posted June 8, 2011 Full flight makes a arms for banshees and 450 shocks but most of them are +3. If they make them you can probably find them on E-bay well i just got a good deal on a set of used full flight +2 +1 a arms for banshee shocks and i need some better shocks to go with them and i can get a pair of yfz shocks for cheaper then a set of after market banshee shocks and im a cheap skate so id rather use the yfz shocks if they will work Quote
vifferman Posted June 9, 2011 Report Posted June 9, 2011 The problem with using banshee a arms and yfz shocks is that the yfz shocks are longer so your front end will be taller. That and the bottom shock mount is smaller on the stock banshee arms so you would have to grind a little bit off the arms to make the yfz shocks fit. I think the Full Flight arm mount is open so the yfz shock will fit but you will be sitting high up front. If you can get a good deal on yfz shocks buy them and see. If you can't use them you can always sell them for what you paid if not more. Quote
