killa b nyc Posted June 5, 2011 Report Posted June 5, 2011 Ok well as you see iam New guy to this Forum of true. shee heads. So I basically need you guys opinion on BANSHEE iam having built.. my mechanic I have is leaning me toward a 4mm set up but I want a 7mm wanted to know is there a big difference in HP ? # 2 iam doing a cub set up custom porting ,and Shear big bore In Frames ,the works except no alky iam going to go wit the Vp.gas..but what size crabs do you guys recommend and what brand? #3. I also Wanted to know being from nyc and we don't go as hard as you guys a lot of grudge matches on 1/8 or 1/4 mile runs we do ..but the dummies I know bet $ cause they live by all these pretty adds in the mag w/ miracle bolt on set up's...so i'am kinda doing my homework and going to drag school 101..and just trying to get a good formula. I had a full blown trinity drag port set up wit a _rz350 tyranny set up on one my bikes but this new build iam going for something I can manage .and Leave hard screaming... I did some business wit Lew swain. From Twister Crank and just hooked up wit Reuben from Rub dub racing ..respect to those guys ..but I respect this site and YOU GUYS insight as well ..HELP..LOLR Quote
Jereme6655 Posted June 5, 2011 Report Posted June 5, 2011 you may want to look into a the new "wompus" cylinder setup....it is specifically setup for street racers. As in it looks to be a fully stock top-end....when really its a mono-block monster. You may also want to re-think your pipes. Big-bore shearers aren't mean for smaller motors.....and when they say they are for big bores.....hell they mean they are for BIG bore motors... Quote
killa b nyc Posted June 5, 2011 Author Report Posted June 5, 2011 you may want to look into a the new "wompus" cylinder setup....it is specifically setup for street racers. As in it looks to be a fully stock top-end....when really its a mono-block monster. You may also want to re-think your pipes. Big-bore shearers aren't mean for smaller motors.....and when they say they are for big bores.....hell they mean they are for BIG bore motors... Cool so let me ask you you dnt recommend the big bores for 4mm or 7mm and also who has the wompus cylinders. I have some cubs .fully ported straight cut gears lock up clutch the works..some what .. Quote
killa b nyc Posted June 5, 2011 Author Report Posted June 5, 2011 you may want to look into a the new "wompus" cylinder setup....it is specifically setup for street racers. As in it looks to be a fully stock top-end....when really its a mono-block monster. You may also want to re-think your pipes. Big-bore shearers aren't mean for smaller motors.....and when they say they are for big bores.....hell they mean they are for BIG bore motors... Yes I found them I may getting those and build a sleeper set up ..but thanks again Quote
