This bike is one of a kind. It is turn key, buy it and ride it. Everything has already been done. It is very fast, handles whoops/turns extremely well, and it is very reliable. Feel free to ask for more pictures, or videos of it in action. This bike has only been ridden in the sand, and it has only been ridden twice since all the powdercoating and work on the plastics has been done. Bike will also come with a spare grill, dirt tires for front/rear, and the air pump for the front fox float shocks. Serious inquiries only! I am selling it because I want to get a Polaris RZR XP. Feel free to ask questions. Feel free to make offers. $5,100.00
Motor:
350cc Ported by Rich Daly at Dynoport Racing, the motor was built around making usable and rideable midrange power, it is not just all top end. (Rich is the 900cc Snowmobile Asphalt drags champ)
Cascade Innovations heavy Duty clutch and springs
Mikuni TM 28mm flatslide carbs perfectly jetted
Carbon Tech Mid tension reeds (custom tension)
Pro Design Coolhead with 18cc domes (185psi compression)
Wiseco Pro Lite Pistons
BR8ES Plugs gapped at .026"
Castor 927 2-stroke Oil 16 ounces per 5 gallons
Maxima MTL 85w trans oil (endurance) 1.8 bottles (change after every other weekend)
Pro Circuit Pipes with flat black Ceramic Coating and 304 Silencers (tested at 89 decibals)
K&N Air filters with outerwears
Cascade Gear Slammer shifter
Dyna CDI with custom Curve Programming
Dyna Coil Pack
13 tooth front sprocket
Stock lightened flywheel
Runs on 110 octane Trick Racing Fuel
Gas Cap vent vent holes modified for increased flow and to prevent vapor locking
Stainless bolt kit on motor
Maxima Coolanol Anti freeze
Mr. Gasket thermo radiator cap
Squish setup at .045"
Chassis:
JJ&A Racing Play Axle with Black industrial coating
22x11x8 10 paddle Skat Trak Super Light Haulers on .125" douglas rims
6" extenxded Podos Racing Round Tube Swingarm with trussed rear shock mount
46 Tooth rear sprocket
Round Housing Axle Bearing Carrier
Revalved stock Rear Shock
Stainless steel rear Brake line
Parking Brake Block off
DID Gold Chain
Frame gusseted and lightened (with steering stop trussed)
Stellar Machine and Performance YFZ450 shock type A-arms +2 +1 (banshee Geometry)
Fox Float EVO-R Front Shocks for YFZ450 1.3" longer shock than banshee, and .6" more travel
YFZ450 Extended Tie Rods (2mm larger diameter)
Dune Runner front tires on .125" douglas rims
Stainless dual front brake lines with holz a-arms clamps
Custom double footpegs with bite angle
TM Desing works rear chain slider
TM Desing works front chain rollers
Cascade Innovations front chain slider
self lubricating delrin front end bushings
Body and Appearance:
Brand New Black OEM plastics race cut with Digital Camo hydrographics and flat clear top coat.
Cascade Innovations seat cover
JD Customs Radiator Grill
Cascade Innovations license plate bracket
Everything done in flat black powdercoat (3% gloss) You just bring this thing home, spray some bike brite on it, and hose it off. It looks show quality.
Control:
Vbars
Works Performance easy adjust clutch perch
Motion Pro twist throttle
Motion pro throttle cable
Motion pro terminator clutch cable
Oury road grips
Billet Handle bar clamp with strobe light switch mount
Electrical and Lighting:
Stock Stator with flaoted ground converted to DC
12v DC Regualtor Rectifier
Werker 12v 10ah battery
Custom Battery mount with circuit breaker mounts
Vision X Solstice Prime P1810 spot beam headlight. 4,120 lumens (stock headlights are 300 lumens each) The headlight will illuminate from the bottom all the way up to the top of boxcar hill at the Dunes in Coos Bay, OR.
Led rear tail light with built in strobe light
Vision X BLUE underbody LED light pods (3)
Custom front light bar mount
Fully 12v DC charging system integrated into the stock wiring harness with all tors and non used components removed from the harness
Picture and Video Link *Click*
I think that's my favorite one on here Snop. GLWS. You done with Banshees for a while, or are you gonna build another after you get your RZR?
I think I will probably just work on banshees and build bikes for other people after I get the RZR. I do a lot of shooting, and I want to focus more on reloading and hunting after I get the RZR done up.
Free Bump for a quality machine
I've ridden this bike a few times and I have to say it is one of the best tuned bikes I've ridden. It is dialed in perfectly, it never skips a beat. I rode it Memorial Day weekend with the new fox floats on the front and couldn't believe how well it soaked up the chewed up sand. It rides like a caddy and is pretty damn fast. The throttle response and usable power is awesome. You can't go wrong here, this is a killer deal!
