so i just took out my stock carbs cleaned them up and i was wondering how do you reset the idle screws? i want to start from the beginning and do them myself because they are off.
Are your TORS on top of your carbs or did you delete them?
This is where the idle knobs on top of the tors are located.
Back them out until he bike almost stalls out.
Then turn them in the exact same amount per side until you like where it idles at.
Only adjust anything when the bike is at full operating temps.
Well dont get all crazy and turn them 100 times.
Just turn them i say 3 full turns out, then do what i said above until you like where it's at. :ph34r:
