Ok so I am giving the old shee a test ride and the clutch lever goes limp. I stop the bike and find the the clutch arm and rod have backed out about three quarters of an inch and now the clutch arm moves freely. I still have the bracket that holds down the clutch arm on so not sure why it came out.
What steps should I follow to get the rod and arm back into place. What do I need to tear down. Do I have to pull the clutch cover off and the clutch off to get that rod back into place.
might have welded the ball in on the clutch adjuster..
take the cover off and remove the clutch assembly and check it all out. remve the actuator and see whats going on.
Lets hope I didnt weld the ball. I will tear her down tonight and see what happened. I was hoping it would be easier then this.
