slag_350300 Posted June 1, 2011 Report Posted June 1, 2011 I ride with the airbox lid off for performance reasons. But I pay for it by having a wet air filter all the time. Is there any tricks or tips on keeping that filter dry without using the stock lid? Quote
Burt Reynolds Posted June 1, 2011 Report Posted June 1, 2011 I ride with the airbox lid off for performance reasons. But I pay for it by having a wet air filter all the time. Is there any tricks or tips on keeping that filter dry without using the stock lid? K and N filter lid,or use the lid and drill some 1 inch holes in the bottom. Quote
bansheesandrider Posted June 1, 2011 Report Posted June 1, 2011 I ride with the airbox lid off for performance reasons. But I pay for it by having a wet air filter all the time. Is there any tricks or tips on keeping that filter dry without using the stock lid? Do you have a Pro Flow adapter on it? You do know that the lid is what holds the filter in place and if you are not running the lid or a Pro Flow adapter that not only is your filter getting wet, but dirt is getting in your engine. Remove the snorkel from the lid and drill some holes in it and install the air box vents. Or if you have a Pro Flow adapter, there is a waterproof cover for the airbox that is made out of material similar to Outerwears, check with Outerwears or K&N for it. Quote
