RC418 Posted May 26, 2011 Report Posted May 26, 2011 (edited) Hey guy's I am looking to see what you all are running for gearing on your banshee with 25" tall haulers? I recently switched to 25" tires and need suggestions as where to start for gearing. Here are some specs of my bike below; -+4MM Stroker (Short Rod) -65 MM Bore (blaster pistons I believe) -Fully Drag Ported by woody @ Action Cycles -LRD Exhaust - Vforce 3 Reeds - Lightened Flywheel -34MM Keihin Flat Slide Carbs (Run 114 Octane Race Fuel) -Custom Cool Head by RK TEK (15:1 Compression) - Driveline Performance Lock Out Clutch W/ R1 Clutch Fibers Edited May 26, 2011 by RC418 Quote
Boston Posted May 26, 2011 Report Posted May 26, 2011 im no expert but you also need to know exactly what your gonna be doing with it, weight of rider, suspension, and length of swinger. Quote
RC418 Posted May 26, 2011 Author Report Posted May 26, 2011 im no expert but you also need to know exactly what your gonna be doing with it, weight of rider, suspension, and length of swinger. Mainly just drag racing at the dunes in Oregon. I weigh 245 & right now I've got a revalved stock shock with the extended spring from Cascade & +6" Swingarm even though that doesnt determine much for gearing. Quote
RC418 Posted May 26, 2011 Author Report Posted May 26, 2011 I forgot to mention they are 12 paddle extreme haulers Quote
RC418 Posted June 2, 2011 Author Report Posted June 2, 2011 41 Rear and 14 Front Thats how I roll What size tires are you running and what gear are you launching in? Quote
BLK'N'YELLOW Posted June 7, 2011 Report Posted June 7, 2011 i think he likes 22x11x8 10 paddle, Quote
Sweet1 Posted July 15, 2011 Report Posted July 15, 2011 i run 22s, but i can tell you 14/41 is not going to work launching in second gear, maybe like a 14 /44-45 may get you close. Quote
camatv Posted August 11, 2011 Report Posted August 11, 2011 i run 14/40 on 78 roll tire on flats. its ok. you will just have to play with it you cannot just hop on the net and ask a vague Q and get the absolute best possible scenario answer. do what others do. get some front sprokets, go to where you ride it at, and play around with the gearing till its whips the bike your racing.. once the front is pretty close you can adjst the rear to fine tune it. Quote
