basically i want to replace all the electronics on my shee. coil, cdi, everything other than maybe the stator. basically i dont know where to start looking or what brands to look at. are these things i can get from a site sponsor or would oem or others from ebay be a better bet? i did not notice anything other than a programmable ignition on rockymountain.
well, the things you gotta look at for replacement are the coil wires/caps, and stator. stock, or personal re-wrap(not ebay, or big company) are the best bets for a stator. there are some good ignitions out there, but stock rarely fails, you pretty much need a good reason to replace it, like added features, or programamble timing curves. there is also the nology coil, which is a good buy, and full pvl ignition if you are just into drag....
And FWIW I havent replaced anything other than the voltage regulator and plug caps on my 2001.
