Fastassbanshee96 Posted May 23, 2011 Report Posted May 23, 2011 Has anyone used the vent block off that goes on the clutch cover to eliminate the hose comig out of it? Quote
SAVAGE420 Posted May 23, 2011 Report Posted May 23, 2011 I never bought the lil plate. But what i did was shorten it so its hidden under the cover and cant be seen. I shortened the one on the back of the case and put a lil one way valve on it so it can breath but not let water in. All is well. Quote
bansheelover22 Posted May 25, 2011 Report Posted May 25, 2011 Has anyone used the vent block off that goes on the clutch cover to eliminate the hose comig out of it? have you guys ever had oil coming out of the hose when it is running or any ever had this Quote
wfobasheeboy Posted May 26, 2011 Report Posted May 26, 2011 have you guys ever had oil coming out of the hose when it is running or any ever had this [/quote Sound like the trans is over filled. Quote
Pooter Posted May 26, 2011 Report Posted May 26, 2011 so at first a little tiny drop of oil blew out but now it's fine, Before they had it zip tied so no air got into the hose. isn't that bad? Now its hanging out after we fixed it and it blew on drop out and is fine now. Quote
wfobasheeboy Posted May 26, 2011 Report Posted May 26, 2011 Has anyone used the vent block off that goes on the clutch cover to eliminate the hose comig out of it? I have the clutch cover vent block off & just running the rear one only. Quote
