Hi guys, i put my engine back together and i bought a case saver just for extra protection lol and i thought all banshee case savers accepted up to a 15 tooth front sprocket, but the modquad one doesnt, which i really dont like cause i wanted to run
15-41 gearing now my question is will a stock size 14 tooth work? is there another brand of case saver that would work with a 15 front? im not sure which route i wanna go yet <_<
Get a T.M. Design works one. Looks to be the most protective. Easy install, and I feel good itle work if needed.
TM Design wont allow the fit of a 15t sprocket either. A little modifying and it will fit but not out of the package.
SP
15 will fit
Can you show us how? Kinda curious because mine will barely accept a 14...
OP sounds like you just need to get out the die grinder and make your own extra clearance for it, just my 2 cents.
Edited by bigblockbanshee
Will take you 2 mins to shave it down with a dremel or even by hand. Tighter the fit the better.
I shaved mine down to run larger sprockets.
