meanv10 Posted May 5, 2011 Report Share Posted May 5, 2011 So i sold my lil bro my banshee and he brought it to a guy to get the floats ajusted. He said that he checked the compression and it was 80 on both sides. So my question is should i try to do this bc he said he would charge 700 for it. And if i do this what all should be replaced? Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted May 5, 2011 Report Share Posted May 5, 2011 So i sold my lil bro my banshee and he brought it to a guy to get the floats ajusted. He said that he checked the compression and it was 80 on both sides. So my question is should i try to do this bc he said he would charge 700 for it. And if i do this what all should be replaced? Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted May 5, 2011 Report Share Posted May 5, 2011 First don't let that dude do it sounds like a ripoff artist. Get a cheap autozone tester and make sure that the psi is really that low. What needs replaced depends on what's wrong. 700 even with parts is super outrageous. Are u anywhere near Cincinnati? Shoot for a top end rebuild I would charge 100+parts. For700 you could rebuild the crank and top end and it could be something simple as a hone and rings Quote Link to comment Share on other sites More sharing options...
meanv10 Posted May 5, 2011 Author Report Share Posted May 5, 2011 First don't let that dude do it sounds like a ripoff artist. Get a cheap autozone tester and make sure that the psi is really that low. What needs replaced depends on what's wrong. 700 even with parts is super outrageous. Are u anywhere near Cincinnati? Shoot for a top end rebuild I would charge 100+parts. For700 you could rebuild the crank and top end and it could be something simple as a hone and rings No im in grand rapids, but thats what i thought i have 2 theories bc it ran fine before we brought it to him, it started hard if it sat for more than a week but if you ran it every couple days it would stat within the first 3 kicks. 1) dude effed it up and now wants me to pay to fix it 2) It was a small maricel that it ran on a compression of 80 lol I dont know the guy and but i cant say that an 88 banshee wouldnt need a rebuild at some point. Ill have to get it back and tear down the top end and see what i find, should i pull the motor for this project? Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted May 6, 2011 Report Share Posted May 6, 2011 No im in grand rapids, but thats what i thought i have 2 theories bc it ran fine before we brought it to him, it started hard if it sat for more than a week but if you ran it every couple days it would stat within the first 3 kicks. 1) dude effed it up and now wants me to pay to fix it 2) It was a small maricel that it ran on a compression of 80 lol I dont know the guy and but i cant say that an 88 banshee wouldnt need a rebuild at some point. Ill have to get it back and tear down the top end and see what i find, should i pull the motor for this project? I wouldnt tear anything down till you did a compression test. Just screw the tester in 1 plug hole at a time by hand per the instructions,kick it over while holding the throttle wide open until the psi wont go up any higher,usualy 15-20 kicks. If the cylinders are over 110 psi each,and not more than 5 psi difference between the two i wouldnt do a rebuild Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 6, 2011 Report Share Posted May 6, 2011 I would assume its had a rebuild being that old but who knows,def dont trust that guy ,this is the reason i started doing my own work,in 2002 i didnt know shit about porting/boring i brought my cylinders to a local guy he tells me 800 for a port and hone because my shit was new,so not knowing anybetter i did it,I decided to pay a visit because he was taking forever with it and when i get there to ask him what type of porting im getting he says all you need to know is i take metal out .Mind you hes drinking heavily and there is two huge rails of coke on the bench.So i said to myself if this idiot can do it so can I Quote Link to comment Share on other sites More sharing options...
meanv10 Posted May 6, 2011 Author Report Share Posted May 6, 2011 I would assume its had a rebuild being that old but who knows,def dont trust that guy ,this is the reason i started doing my own work,in 2002 i didnt know shit about porting/boring i brought my cylinders to a local guy he tells me 800 for a port and hone because my shit was new,so not knowing anybetter i did it,I decided to pay a visit because he was taking forever with it and when i get there to ask him what type of porting im getting he says all you need to know is i take metal out .Mind you hes drinking heavily and there is two huge rails of coke on the bench.So i said to myself if this idiot can do it so can I The coke helped him focus, lol. Hey is there anyone on ebay that is a member hear that i could by stuff from? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 6, 2011 Report Share Posted May 6, 2011 What do you need,my advise is check comp first if its down under 110ish,pop the cylinders off and send them to be checked,if you were closer i would check them for you,if the person checking them knows shees then they will know if it need pistons of just rings Quote Link to comment Share on other sites More sharing options...
