greenskin77 Posted May 3, 2011 Report Posted May 3, 2011 i posted this is many forms untill i found the site. so heres the deal my bro has a banshee brand new maybe 10 hours totall. all stock excpet advabnced timing plate and tors remover kit. at first it ran fine no over heating AT ALL. ran like this for copule sundays 2 hours a day . then the piston came aprt and locked it up on sunday( on the over heating side ) kicker side ..... now after putting in the new rings and piston it get shot FAST very hot withen 6 minutes of ideling it to hot to tounch and starts to boil over ... just one the kicker side only .. the other side nice and cool . you can touch the pipe with your hand and not get 3rd degree burn like the other side lol. i did everthing i can think of i didnt find no leaks around anywere unless i am doing it wrong. any info thanks. Quote
Larry's Shee Posted May 3, 2011 Report Posted May 3, 2011 (edited) Being brand new only thing that comes to mind is possibility of not all of the casting sand was gotten out at the factory and is plugging the head most likely. Where you at that you picked up a new Banshee? Do a leak down test to eliminate possibility of an air leak. Should be a sticky on how to do it/make tester. Here you go http://bansheehq.com/forums/index.php?showtopic=110585 Edited May 3, 2011 by Larry's Shee Quote
06specialedition Posted May 3, 2011 Report Posted May 3, 2011 Hows the jetting? It could be running lean Quote
greenskin77 Posted May 4, 2011 Author Report Posted May 4, 2011 well its a 2005 shee my bros..bike he bought new then but left state to work for years untill 2010 got back had kids and never rod eit ... so jetting is factoyr.. and i had other people tell about it might be lean... i even clean the carb and swtched carbs with my shee it still over heats.. i changed cdi i even switched around the plug wires it didnt change a thing. i didnt do a leak down test yet. but it leaking on the kicker side wich holds the oil so in my other shees when that seal went out it smoked and kinna leaked oil from the exhaust manifold. so i dont see how it would be lean on that side. Quote
Larry's Shee Posted May 4, 2011 Report Posted May 4, 2011 carb boot cracked/dryrot, leak at crossover , oil low thus not sucking oil, leakdown test will help eliminate a lot of possibilities. if possible post picture of old piston Quote
greenskin77 Posted May 4, 2011 Author Report Posted May 4, 2011 carb boot cracked/dryrot, leak at crossover , oil low thus not sucking oil, leakdown test will help eliminate a lot of possibilities. if possible post picture of old piston oil low hmmm i will check that tommerw and i will get the leak down test er made .. see what she reads out on but the boot i changed didnt help iut. cross over ? do u mean the cross over bettween intake boots or the between the chokes on the carbs Quote
Larry's Shee Posted May 4, 2011 Report Posted May 4, 2011 (edited) Intake crossover/balance tube, but you changed boot. How much time was on before storage? How much since? Edited May 4, 2011 by Larry's Shee Quote
greenskin77 Posted May 4, 2011 Author Report Posted May 4, 2011 Intake crossover/balance tube, but you changed boot. How much time was on before storage? How much since? yep i changed the boot ... like i said maybe 3 or 4 hours he put on the bike the next day after he bought it .. then left state for work. been stored scnce ..he got back n got it out it ran good for few days maybe 2 hours each day at the most. then bammmmm piston broke locked motor up becase piceses of the ring got between the head and piston so u couldent kick her .. we bought new piston n rings and from that point on it get red hot in like 6 mintues Quote
bansheesandrider Posted May 4, 2011 Report Posted May 4, 2011 i didnt do a leak down test yet. but it leaking on the kicker side wich holds the oil so in my other shees when that seal went out it smoked and kinna leaked oil from the exhaust manifold. so i dont see how it would be lean on that side. This thing has the classic signs of an air leak- you can have a leak on the right side at somewhere OTHER than the crank seal. Head gasket, reed gasket, base gasket, etc. The fact that you MELTED a piston says the you have a lean condition. Quote
