96 ci Posted April 29, 2011 Report Posted April 29, 2011 What is the best way to align a banshee front? Quote
fastquad02blaster Posted April 30, 2011 Report Posted April 30, 2011 Tie rods will adjust the toe in and out. You want just a touch of toe out in my opinion. Quote
thomas h. Posted May 1, 2011 Report Posted May 1, 2011 if stock 0.) check for slot in joints. upper banshee arms get bent and sloppy, better if the front end is off the ground 1.) set air pressure 2.) get your buddy ( close to yuor weight ) to sit on it 3.) i like about 3/16 - 1/4 toe in ( or pigeon toed )which is adjusted by the steering rod 4.) check for slot in joints upper banshee arms get bent and sloppy, better if the front end is off the ground contact aftermarket arm dealer for correct alinment settings ( primary riding style ) Quote
bansheesandrider Posted May 1, 2011 Report Posted May 1, 2011 Tie rods will adjust the toe in and out. You want just a touch of toe out in my opinion. If it is toed out it will turn better, BUT if it is toed in then it will be more stable and track better at high speed. With the rider's weight on the bike I would set it at 1/16-1/8 toed in. Quote
fastquad02blaster Posted May 1, 2011 Report Posted May 1, 2011 If it is toed out it will turn better, BUT if it is toed in then it will be more stable and track better at high speed. With the rider's weight on the bike I would set it at 1/16-1/8 toed in. Thanks for that one. I didn't know that. I knew mine handled pretty well in dirt on turns. I have to check mine again now and see where it's at. Quote
