bksdesign Posted April 20, 2011 Report Posted April 20, 2011 Can I change my bike from a twist back to a thumb throttl with out syncing the carbs? Thanks Quote
bksdesign Posted April 20, 2011 Author Report Posted April 20, 2011 Can I change my bike from a twist back to a thumb throttl with out syncing the carbs? Thanks oh yeah I have a motion pro twist throttle on there and ordered a use thumb trottle I thougth was stock (it says banshee on top in polished aluminum) will the motion pro cable set up just hook up to the thumb throttle? Quote
Wildcardracing Posted April 20, 2011 Report Posted April 20, 2011 No, the thumb and twist throttle cables are different. And you will need to re-sync your carbs. Anytime you pull the caps you should re-check the sync of the carbs even if you didn't make any adjustments. Do you still have stock carbs? Tors or is it deleted? -Brandon Quote
bksdesign Posted April 20, 2011 Author Report Posted April 20, 2011 No, the thumb and twist throttle cables are different. And you will need to re-sync your carbs. Anytime you pull the caps you should re-check the sync of the carbs even if you didn't make any adjustments. Do you still have stock carbs? Tors or is it deleted? -Brandon I have stock carbs with tors removed and motion pro twist throttle. I bought the thumb throttle piece that goes on the handle bars. Do I use a stock cable now or what. With the tors removed and caps on the carbs isnt the cable diffent now? How do I get a cable that will fit? Quote
bansheesandrider Posted April 20, 2011 Report Posted April 20, 2011 I have stock carbs with tors removed and motion pro twist throttle. I bought the thumb throttle piece that goes on the handle bars. Do I use a stock cable now or what. With the tors removed and caps on the carbs isnt the cable diffent now? How do I get a cable that will fit? You need to get a TORS delete cable from Motion Pro. The TORS delete cable is different from both the factory thumb throttle cable and the twist throttle cable. It will hook up a stock thumb throttle to the TORS delete carb tops. AND you will have to resync your carbs. Quote
